Results 1 to 2 of 2
Thread: 2005 Mitsubishi Magna TW Camshaft Questions
    Aug 2019
    Default 2005 Mitsubishi Magna TW Camshaft Questions
    Just Purchased a 2005 Mitsubishi Magna TW ES Station wagon 2 weeks ago, it has a set of Pacemakers Extractors on the car, I also have a set of Ralliart Camshafts stamped #7, I will be replacing the timing belt soon and was wondering
    1. Is there any difference between the stock Magna V6 3.5L camshaft and the Ralliart Camshaft?
    2. Is it worth doing the swap over?
    3. Any special tuning needed?
    I'm new to this forum any info would be much appreciated, thanks in advance
    May 2008
    Yep the Ralliart has more lift and duration than the standard cam, most of the gains are in the high rpm range. You already have them and while doing the belt it's the perfect time to fit them.
    Hope this helps.
